Digital guages
Free spin, spindle nut socket size?
Kudos to Mopar4Less!
I am going to install some guages in my 05. I was thinking about digital guages and was wondering if anyone had used some Teltek USA. They are supposed to be lifetime warrenty. Any opinions or other options welcome. Thanks Harry
I had a two double SPA digital gauges on my '01 and loved them. They were quite expensive, but I really liked some of the features they had such as: max value recall, alarm settings (to beep when exceeding a user defined limit), etc... . The gauge face didn't blend in as well with the factory gauges and the display was little on the bright side from what I recall. They looked pretty intimidating through the window at night! :)
I had Dakota Digital gauges in my '01 and was very happy with them. I am going to use Dakota Digital again for my Boost, EGT and Transmission Temp in my '07.
I also use the SPA dual gauges. I had 2 faces that gave me info on 4 parameters.
I removed them from my old . 01 Dodge and used the one EGT/BOOST in my '07,5. 9. I had an extra pressure sending unit so I got a switch and I can now read my primary fuel pressure after my filters and then switch it to read my boost.
My only digital gauge is a Dakota Digital fuel pressure gauge. It has been absolutely flawless for 5 years now.
-Ryan
