dimmer switch wire
Has anyone installed a Crank up spare in 1st Gen
lost pwer found
Installing boost an transmission. temp guages . Need location dimmer wire to gauges. Have Headlight switch out. Which wire anyone? Bob
Bob,
In the newer trucks the dimmer wire is "Tan" in color, off the light switch. Might try looking for a tan wire and confirming it with a volt/ohm meter... ;)
Tan is Good
Manual says it's an 18 ga tan wire, you can also pick it up at the fuse block from fuse #14 (3amp).
Neil:D
