Rail Pressure Gauge Installed
Well finally got the Rail Pressure guage installed. Not bad, it took me about an hour. But that was mainly spent trying figure out how to best manage all of the wires, tubes, controller cables going through the firewall. 5 gauge wiring and sensor cables and 3 controller boxes all fed through the same 1" hole drilled in the plug in the firewall. With all the Dodge wiring web and mine together kind of busy under the dash.
Well I do have one suggestion on the lighting/power wiring harness. The dimmer pod is too close to the gauge for me. It is not long enough to reach outside of the steering column pod and not be stretched against the pod. I had to wrap it up some inside the pod. This makes the sensor connector close to the edge of the pod. It works ok because I did tap the dimmer power for the light wire and don't need access to the gauge light dimmer pod.
Just went for a short test drive. I have disconnected the EZ, unloaded the downloader and set the TST 0/0. That is as close to stock as I can get.
Idle at 7k in nuetral. Idles about 7. 5k in drive stopped. In general the gauge mimics the movement of my tach almost exactly on throttle. The movement fluctuations going through the rpm range and shifts is in sync with the boost levels. This does make since ECM sees more air and matches with more fuel.
With stock settings I saw max of about 23. 5k on hard acceleration. With TST on 3/1 only saw about 23k on hard acceleration on my short test run. I will be plugging the EZ back in and doing more testing. Tomorrow I plan on being at the track again and will see what Smarty stacked will show and see if I can determine exactly at what setting point I drain the rail.
Very happy with the guage, THANKS DOUG for the R&D .
BTW after I connected the battery cables my dam trans temp gauge reads 150* now instead of 0. Don't know how that happened. I did have my console pulled off to get to other wiring, but should not have had any effect on those guages. The only wiring to that gauge is the lighting and it still works fine. The sensor cable is one piece from inside gauge to sensor, kind of hard to screw that up. Irritating
at best.
Couple of pics, dam camera seems to have poor vision lately also.
