Checking the oil last night, I was shocked to see that it was about a quart below the full line.
I'm thinking WTF is going on here. When I inserted the stick in for a double check I noticed that the whole tube shifted back as I pushed the stick into the tube. I loosened up the mounting bracket, and pulled the tube forward and re-tightened. Did an oil check and it is almost to the full line. I have not been getting consistent level readings from the dipstick since last May. I'm not losing oil out the exhaust pipe or after the exhaust turbo and the only visible oil is from the puke tube, so this has been perplexing to say the least. Has anybody else experienced this?
My dipstick always showed about a quart over the full line including right after oil changes with one quart in the filter and ten in the crankcase.
