This is not new information (and my apologies to Gary, I didn't perform a search before posting this). Others have previously posted similar information. I'm posting it only to remind anyone who may have been experiencing mild overheating when pulling a long grade while loaded heavy.
I've noticed for the last several months that the engine temperature gauge of my Ram with 145k on the odometer reads higher during long climbs than it once did. Others have mentioned road debris build up in the radiator fins, some of it caused or contributed to by oil vapor from the crankcase vent. I asked a friend who is a mechanic in a local Dodge dealership to pull the radiator today. I expected some debris but was surprised to find a thick layer of crud on the front side behind the intercooler and also oily crud on the backside. My mechanic friend sprayed on a grease remover, let it soak a while, then pressure washed the radiator. He reinstalled it with new upper and lower hoses, a new thermostat, and fresh coolant mix. I expect that will cure my mild overheating.
He also adjusted the valve lash. I had always held the opinion that the 24 valve engine required a valve lash adjustment at 150k miles. I was surprised, and a little embarrassed, to read in my owners manual today that according to maintenance schedule B, which is severe service, the valves should have been adjusted at 125k miles not 150k as I thought "I knew. "
I hope this serves as a reminder to someone else who may be experiencing minor heating.
Harvey
Harvey
