I would plug it and see if it does go above 35 if not it will run strong. The elbows are tricky cause they just delay the pressure to the WG no matter how you set it eventually the WG sees 22 and opens, your boost will peak every time you goose it and then fall back to 20-23. With the plug you can hold above 22 with half throttle or less, very nice towing. With stock sticks and a timing only type box you shouldn't see over 36 if that ever.
If I still had stock sticks and Hx 35 I wouldn't ever run it unplugged. Its too laggy for a little turbo, on the bottom just to fall off as soon as it peaks IMO. Then again you could say im spoiled with my lighning quick PS62
