Hmmm... I found my service manual, and despite what I remember reading here there doesn't appear to be a proportioning valve in the system--the closest thing seems to be the Rear Wheel Anti Lock (RWAL) valve by the rear axle.
Is the proportioning valve a 2nd gen thing maybe?
The whole reason I had wanted to do this was because I wanted to try to increase rear braking power. Yes, yes, I know about going from 2. 5" shoes to 3" shoes, and going with larger wheel cylinders. However, my rear brakes are barely even being used now--this winter on slick streets my front wheels would lock up if I just LOOKED at the brake pedal; on the other hand, on that same slick street I'd have to STAND as hard as I could on the pedal to get the rears to even begin to lock up.
What I ended up doing was throwing it into 4wd almost every time I had to stop, and that gets real hairy if it's a panic stop. According to the service manual, engaging 4wd disables RWAL, so I'm wondering if that's where my increased braking is coming from.
From looking at the manual, it looks like I can disable the RWAL valve by disconnecting the harness from the controller box under the passenger side of the dash, or also from the valve itself by the rear axle.
What kind of problems might I run into if I unplugged at either of these locations?
Thanks,
Mike
