MacGreenie
Okay Folks,
I am stock for now (1998 24V) but the bombing virus has got a strangle hold on me! I am ready to get started... by the way, as my signature shows, I am fully instrumented and see way too much information (is that really possible?) about what is happening under the hood, at the transmission, etc. .
If I disable the wastegate by disconnecting the vacuum line and stuffing a pipe plug in there (or using a turnbuckle) I understand I will get lower EGT's but no real improvement in performance.
I assume the engine will simply get more air and achieve better and more complete exhaust scavenging and that lowers the EGT's? Right?
Will the engine run "leaner" because of the turbo stuffing more air in than was designed? I know with gassers the heat quenching capability of the fuel/air mixture is important. Lean running means scorched valves and engine damage. My understanding is that diesels send most heat downstream via the exhuast and the heat in the combustion chamber issue is different than a gasser.
I can wait until I get my Edge or Comp box to fiddle with the turbo... . just wondering what benefit I get if I disable the wastegate now. Do I need different boots on the intercooler lines due to increased boost? I assume I might see 35 psi from a stock turbo. I believe stock boots will not blow off from that sort of pressure.
Also, I understand these Edge boxes have a boost module that alters the turbo behavior as well... or do I need a second box (or just a turnbuckle) to do this?.
I am a long time lurker and have read all these threads voraciously... but, alas, these simple answers still elude me!
TIA!
MacGreenie (still stock and dreaming of more horsepower, smoke, noise etc. !)
TIA!
