Disc Conversion on 2001 from 2001.5?
ROMO BOMB VICTO
Retro 2001 Foglights to earlier with Auto trans?
I was wondering if there wouldn't be any reason you couldn't do a disc conversion on a 2001 with a 2001. 5 rear setup, anyone have any ideas?
TAZ... 2001 2500 SLT+ 4X4 Auto ETC Cummins, LSD 3. 54,Quad Cab, Long Bed, Agate Leather, White/Driftwood Exterior, Sliding rear window, Camper Special Group, Towing Group, Cab clearance lights, Diesel Dynamics Stage-3's, DD Boost Module,SPA-Technique Digital Dual Gauges (Pyro/Boost, Trans pressure/temp) Aux. Backup lamps. BNM 5th Wheel Hitch, Additional Body Molding on Bed. BD Torc Loc, BD Pressure Loc.
2000 32' Aljo Triple Slide 5th Wheel.
http://www.ramtaz.com
Add on's to come: Exhaust Brake, Power Edge Box, B. K. 's TC and Valve body, Line-X bed-liner, and any other Ram Runner required modification...
well David Craig said the new 4 disc setup is realy nice, so I want to see if I can do the conversion. I would not think it would be difficult because all of the axles stuff and brake sensor stuff should be the same with the exception of the parking brake.
I think the swap may require a new master cylinder and equalization/proportioning valve as well. Calipers generally displace more fluid than wheel cylinders.
Dave D
