The problem exists in EVERY 12 valve engine produced from 1989 till 1998. Cummins says they made a change in 1998, but doesn't specify if that change went into effect with the ISB introduction or with the last of the 1998 12 valve engines. From the stance Cummins originally took on the original dowel pin problem and its questionable existence, I'd get even a 1998 12 valve engine done the CPFF way just to be safe. I personally have done that service to about a dozen first gen trucks and have had to remove the cover off of one 1990 engine because the dowel had creeped out so far, I couldn't bottom the drill bit in the case. That one felt really good because I knew that I had spared that owner about ten thousand bucks. Get them all done... . it's a rarity, but it does happen.
