Long story Reddog 1...
I lowered the rear of my 99 2" about 6 months after I got the truck. I saw the brake proportioning valve (left side frame... just behind rear axle) and felt that without changing the length of the connecting rod, my truck would "think" it was loaded all of the time. I marked the angle of of the arm before I started the "ride height" modification. My last step in the "modification" was to put a turnbuckle on the connecting rod to "reset" the valve back to the factory angle.
Since that time, I have "fine tuned" (so to speak) the length of that rod for winter vs. summer driving. (I use two different setting. ) Well this is my typical "farmered-up version.
I have been thinking that a cleaner setup would be a "verneer-throttle" type setup, mounted either in the cab or somewhere in the rear, so that I would not have to "get dirty". Actually, what I have is real easy to adjust (and it does not take much to make quite a difference). Like the old saying "Speed cost money! How fast do you want to go?"
I guess I chose to "trot"!!!!
One final word of caution in attempting all of this. Disc brakes tend to hold "better" the hotter they get, thereby destroying themselves and saving the rig and its passengers. Drum brakes, on the other hand, tend to fade as they get hot, thereby saving themselves at the expense of the vehicle and its passengers. So be please careful in any modifications you are considering to the factory setup.
This should work on a 96. I believe you have the same valve setup as I do Reddog 1.
