Seems like my truck isn't performing quite up to snuff. Here's the situation. 80deg, go pedal floored, in overdrive at approx 72mph with an 8000# trailer. The most EGT I can get out of her is 800 deg (post turbo), w/boost at 29psi, RPM at 2200. I swear last summer I could have run the temps right to the limit (my personal is 1000 post turbo) and would have been able to generate as much as 32 psi boost.
In 3rd gear, if I run the RPM right up against my limit, at about 2800 rpm I can get to 31 psi and climb the EGT's to 950+.
Basically I have to wind the motor more than I think I used to in order to generate EGT's/boost numbers I'm familiar with.
Here's one more piece. I was tagged in the front end by a semi last winter. Almost everything forward of the water pump is new.
I was concerned about my pump after the wreck because of some throttle linkage binding. But after we got the bent sheet metal out of the way everything appeared to be working great.
My theory is that for some reason I'm delivering less fuel than before at higher rpms. I don't think it's a leaky intercooler for two reasons. 1. I'm still able to generate my same old max boost and 2. If I was leaking air but still delivering the same amount of fuel... . I should have no problem maxing out my EGT's... instead of coming up short.
Any thoughts out there on evaluating whether my pump is delivering it's full and normal fueling? Specs on throttle lever movement etc. ?
How about my AFC? Could there be a problem with the boost feedback part of the fuel control?
I won't argue about checking my new intercooler... . I'll check it. Any good techniques out there that don't require a professional plumber to check the integrity of the intercooler? I do have the air compressor.
I almost hate to chase this. The truck runs great... . just seems to come up short when asking for max power out of her in overdrive.
Thanks ahead of time for the thoughts fellas,
Cheers,
Gill
Cheers,
Gill
