Took my 04. 5 6 speed in for the problem I spoke about earlier and they could find nothing wrong, let my try to explain the problem and get some good advice from you all. Mechanic drove the truck and said everything was normal but the truck is doing something now that it never done before, I have 8400 miles on it. On pulling out I use 2nd gear and never need any gas, when I let the clutch out the truck makes a vibration, this also occurs in 1st gear, the problem is worse when decelerating and downshifting as I mentioned earlier if I let the engine bog at all when I press the clutch in I hear the noise and you can hear the body vibrate. Yes, I know I shouldn't bog the motor but the truck never did this before, I have experienced this lotsa times in other vehicles and I know it's normal but this is a change from previous in my truck and it can be very exaggerated at times. If I keep the rpm's up and press the clutch in it does not make the vibration. Does anybody else experience this and what do you think it is? Clutch, maybe but I baby the clutch and the truck is brand new.
