Okay, 6 psi's at WOT isn't bad, although Steve St. posted that they now want no lower than 8 psi's at WOT, I'm doubtful that 2 psi's make much a difference as long as you have positive flow to the injection pump. If I were you and if you are concerned over the warranty, I'd buy enough of those bored out banjo bolts from Geno's Garage to replace all in bound banjos. That should be enough for you right now. More fueling demands, such as larger injectors and or another fueling box may make it necessary to change to something different, such as Weber fittings in replacement for the banjos. You are not calling for a huge amount of fuel with the EZ and the stage 2 injectors. Hope this helps !!!
Scott W.
