Hey Andy,
I wish I'd been around a while ago to chime in on that thread. Keep in mind, what I'm about to spew out here is simply opinion and info gathered from my own observations over the years.
Most timing and fueling boxes will provide a "shock" at the RPM where they begin taking effect. The reason for this sudden kick in the pants feeling is that the box is providing enough fuel/timing advance to build RPMs quickly. As well, the torque curve will now tend to rise steeply to 1750 - 1850 RPM, and then begin to level off. However, this shock usually doesn't start until 1400-1500 RPM, which is where the box truly begins to take effect. If you were able to get dyno numbers down at the 1100 - 1200 RPM area, I suspect you'll see numbers very close to stock levels, as the box has just barely started operation, if it has at all.
Injectors, on the other hand, will tend to be a smooth curve that follows the stock curve (assuming you don't have a fueling box attached). This smooth curve will tend to cover the fact that you are indeed making more torque at 1200 RPM than you would with a fueling box or stock.
Personally, for the best drivability, I feel a mild set of injectors (RV275s, Stage 2's) coupled with a fueling box is ideal. The injectors provide some bottom end fill, reducing the "shock" when the fueling box really starts to pour it on. Your result will be a torque curve that is steep to 17 or 1800 RPM, then gradually climb to 2400 RPM or so, before letting down.
