Do the "chips" cancel the rev limiter?
Want to loose banjos
Factory Borg Warner S300G
Have an 03, 3500, 6sp, 4x4, bought the edge EZ, it made a totally different truck out of it, i love it, but was disapointed that the truck will still only run 108 mph, I THOUGHT THE CHIPS CANCELLED OUT THE REV LIMITER!! I've heard of diesel trucks that just keep climbing, sometimes to 140mph (I know if i want speed i should get a sports car). Anyone know how they atain 140 mph?
The 3rd gen trucks are still limited to the OEM RPM limit... . The 24v trucks can go with the Blue Chip Redline box and get additional/unlimited RPM. Then you have the 12v trucks with the p-pumps here RPM is pretty much unlimited up to what the engine can take.
Now if it the truck speed limiter you are reffering too, then BD makes a Top speed eliminator that will allow you to pull all the way to redline in top gear.
Doug Smith
JRothgit said:
Thanks for the good info, sounds like you know your stuff. james
You *could* say that he's picked up a piece or two of knowledge over the years. ;)
Doug, how many years ago was that 746hp run with the B1 and spray?
