I'm concerned about egt's. Traveling to Seattle from Portland tonight I watched the pyro more than the road, truck was empty and I was particularly concerned about the temps while on level ground, please review the numbers below and let me know if there could be something wrong or if it is normal. See sig for truck info.
cruise control set at 67
rpm at 1900
outside air temp 61
boost at 5 to 6 psi on level ground
fuel pressure 17 psi steady
egt temps were between 700 and 800 pre-turbo and would ease up to 1000 to 1100 pretty easily on gentle grades. I've heard a lot of reports of people only running in the 500 to 600 range under similar conditions.
if you need more info, don't be afraid to ask.
rpm at 1900
outside air temp 61
