Competition Do we need Cages'
Competition edge drag comp?
Off Roading Hydrosteer plumbing
He was very fortunate it look like.
I always recommend at least a 6 point to anybody getting even remotely serios on the track. My rule of thumb is this; If you run slicks then you should have a few bars wrapped around you.
My little truck (ABBY as we call it) has a 14 point (really a 10 with extra bars for strength)
It's worth the peace of mind. The cage in ABBY doesn't interfere with entrance or exit of the vehicle and is not uncomfortable in any shape form or fasion.
There comes a point where you need to decide if YOU have enough safety equipment. The rules at the strip were not intended for trucks (or anything with this weight or overall size/height). We are much more likely to roll one over than a car running the same times/speeds.
Everybody on the boards should see this video as a reminder as to why so many guys on here preach about safety equipment.
It very well may save your life one day.
~Wes~
Here's a pic from the inside of ABBY.
This is the minimum that I was comfortable with for what my intentions are for this truck.
~Wes~
What Happened
Hope the driver was ok.
Anyone know what happened to make the truck go out of control?
Good Post
Thanks
Cliff
Good Post
Thanks
Cliff
My guess is it blew a Freeze plug and watered the tires down, I've done it but it wasn't that wild of a ride, then he over corrected intially.
Jim
WOW... ... . nasty, Looks like it dumped something water/oil and got loose. Besides a cage a diper on the engine and trans is a good idea as well.
11.99 and faster
I though was the rule to have a roll cage in any vehicle (expect snowmobiles and bikes and what not) if you running faster then 11. 99?
Thanks MASS for the story.
About the 11. 99 rule.
NHRA changed their rule to 11. 49 for a 6 point Roll Bar
and 9. 99 for a cage (I know the 11. 49 is right the 9. 99 I'm pretty sure is right)
~Wes~
Just a few thoughts for everybody reading this to chew on:
Although we now know the cause of this accident. Here are a few things that could potentially cause the same type of wreck.
Blown Headgasket
Blown Freeze Plug
53 Block crack
Blown coolant hose
Blown radiator
Severely cracked head
Broken ring/pinion
seized motor
rod/rod bolt failure
transmission failure
There are more, but the point is this: Any of the above failures could cause loss of control by either wetting/oiling down the track or by locking up the tires and causing loss of traction.
We all need to keep this in mind when we're building our high horsepower trucks. Safety is far more important than we often realize.
~Wes~
sorry guys I have suspended the viewing of the video I had actually forgot it was on the site so when I posted the site for other members to see my winter project, the phone calls have been endless, my appoligies to the Derrick crew, their was no intentions to spot light anything or any one.
