Originally posted by Bill Kondolay
For the record,
This whole thing for me started when i read the post about prime loc causing lift pump and the vp44 pump failures.
I found the whole post very interesting, and somewhat confusing, and i must confess i cheated while doing some of my r&d. I hired an engineer to check out the system but wanted to verify his findings before commenting.
I'll be honest with you , i thought this could be a good business opportunity, selling a complete fuel system upgrade.
When the engineer gave me his findings, his findings suported prime loc that pressure has very little meaning without flow.
Obviously i have invested a great amount of money to date in this project, i however believed it would be a good investment at the time.
Much to my chagrin, our testing proved the engineer and prime loc's position.
Based on all our findings, the most effective method is to simply move the oem lift pump closer to the tank and clean up some of the fittings(banjo bolts).
Installing a bigger line to feed the existing oem pump or aftermarket high performance pump at its factory location is a waste of money.
There really was no politically correct way of saying this, i know a lot of people have invested a lot of money.
I am not an expert in fuel systems but i have to conclude as long as your pressure does not drop below 2 psi,you will be ok with the oem system as is.
Next upgrade from there in my opinion would be to move the oem pump closer to the tank.
Keep in mind those of you in cold weather climates, the engine compartment does provide a warm location for your fuel pump to protect the fuel pump from geling.
From there a slightly higher flowing fuel pump located closer to the fuel tank, and once again if cold weather is a factor , the engine compartment is a warmer climate area.
Let me know how you feel about our findings, i am a transmission technician and i am trying to learn about the fuel systems just as you are.
Bill Kondolay
Diesel Transmission Technology
