I have a 98. 5 3/4 ton 4x4 Dodge diesel. I have and have had front brake trouble from day one. When applying brakes the truck pulls to the left, drivers side. I have put on new calipers and pads, flushed the system. When I have to apply the brakes hard it will pull or dart to left. But if you let up and reapply the turck will pull straight. I ordered a service and repair manual when I bought the truck. It tells you to check back brakes at 5000 miles as a tight brake will puill. On the backing plate there are 4 rubber plugs... 1 forward, 1 aft, two on bottom. I had an old military jeep that was the same and to adjust brakes you use a feele gauge. But in my book it has no specs so I am using 15/thousands and 18/thousands and they may be wrong. The next thing is I am going to change the rubber hoses to the wheels. I have changed, adjusted, cleaned, and turned till I am at a stand still. I would welcome any help anyone can give. Thanks
J. Wagner
North Fork, CA
J. Wagner
North Fork, CA
