What would you guys suggest the first thing to do in a 85 Dodge crewcab conversion? I have a good running crewcab, complete parted out 90 D350 Cummins engine, 2wd 5 speed Getrag trans, and Dana 70 dually rearend. I finally have a second ride, now I can afford to down the crew. I plan to use the 85's wiring to power the injection pump. No grids or fuel heater, at least at this point. I don't need the message center lights to work either.
I basically looking for a starting point or step by step process of the conversion. Get the 360 gasser out and to the side, notch the engine cross member and sit the Cummins in, then measure for the transmission mount, etc? What do you guys think?
