Dodge, Year 2001, 3500, AT with 4. 10 rear end. 35,000 miles. 4 WD. When towing 5th wheel on long grades I sometimes overheat. Dealer replaced thermostat, no help. Overheating even occurs when outside temp around 58 Degrees. I'm towing between max rated load (20,000 lbs gross) and occasionaly 10% over rated load. Problem seems to occur only when above 7,000 feet. Any ideas on cause. Dealer stumped but has not attached scan tool and says it won't help. Power seems adequate and engine runs fine.
Can anyone tell me how the fan clutch works. I got two different stories from dealer. At times when engine temperature starts climbing I hear a roaring noise from engine compartment that sounds like a fan speeding up and sometimes I see engine temp begin to drop, then noise decreases. One mechanic thinks it's torque converter noise. Fan clutch seems tight and stops spinning immediately at engine shutdown.
Any devices out there that would allow me to lock my Automatic transmission in any gear I want. ? Forced to downshift to 2 nd gear on steep hills because transmission shifts violently between 3rd and 2nd.
When I take transmission out of overdrive is that same as locking up torque convertor? Obviously I'm lacking in automatic transmission technology!!
