Apparently they don't:
Knock sensor on Dodge Engines? - HP Tuners Bulletin Board. The suggestion is to use a cooler spark plug.
If you have that much ping in your bling, you might have carbon or other build-up in the cylinder that causes hot-spots, which then cause detonation. Or the EGR could be carboned up. If you're adventurous, you might try holding the RPM at 2500 and pour a small, short trickle of water into the TB a time or three. That's usually enough to blast carbon free. If you see a black cloud exit the tail pipe, you'll know you've got carbon built up. On old engines, I would occasionally get the engine het up, set the RPM up high and trickle a cup of water into the carb; I would sometimes get a huge cloud of black smoke out the exhaust.
Seafoam is a decent intake/cylinder cleaner and is probably the safer method.
Or add octane boost to slow down the burn. Gold Eagle's 104+ should be good. Amsoil's booster is also good.
