1st problem last year high beam head lights go out traced it down to broken wire at multi function switch right at the little connector in the harness plug. Fixed with easy didn't think that much about it. 2nd problem pulling in to work today truck dies totally before I make it into a parking stall already late I left it till after work start with ign fuses none burnt moved column and the power comes back pull apart and found the main power wire to the ign switch broken in the middle of the wire WTF not at a weak point but right in the middle of the wire and I see other wires with the insulation cracked or cut. I fixed the wire but this is NUTS!! with only 97k on the truck do I have a life time of wiring nightmares ahead of me?? Any body else have similar troubles? Are the harness's made in Taiwan?
Craig
Craig
