Does anyone make a combo gauge for 2nd gen.?
Anyone use a Truspeed speedo tool on an '06?
Fuel fills
I'm just about to buy a bunch of gauges (fuel, egt & trans temp) I was just wondering if there is a combo gauge or somthing like the Edge monitor for a '94? I've been looking but can't find anything.
Westach has standard dual combo gauges and will custom build gauges to order as well. Some of the standards are available through Geno's Garage; for a wider variety of standards as well as customs, I'd work with Westberg Manufacturing directly. That's what I did to obtain my dual combo fuel pressure gauge (pre-filter and post-filter).
Rusty
Wedge said:
I don't see one for a '94!?!
Don't see this as a real problem. If your taking about mechanical gauges, they should work on your 94. You just have to find out where to connect the sensors to (ie EGT to the exhaust manifold, boost to the air intake on the in-take manifold, fuel pressure to somewhere after the filter, etc. ) The gauges only measure a value. They don't care what year your CTD is. Now if you're talking about some fancy multi computer gauge, all bets are off... ;)
RJOL said:
Don't see this as a real problem. If your taking about mechanical gauges, they should work on your 94. You just have to find out where to connect the sensors to (ie EGT to the exhaust manifold, boost to the air intake on the in-take manifold, fuel pressure to somewhere after the filter, etc. ) The gauges only measure a value. They don't care what year your CTD is. Now if you're talking about some fancy multi compter gauge, all bets are off... ;)
Yeah, I was thinking of the quad commander or something like it. I'm not sure how those work. If they we're like a mechanical or electrical gauge then I'm sure I could make one work.
