Im wondering if installing a fuel cooling device inline with the fuel line would increase or decrease performance of the diesel engine.
I know with gas engines that cooler fuel is a good thing.
From what I have read the cp3 uses a portion of the fuel for lube and recirculates it into the fuel filter housing. Do you think installing a fuel cooling device betweent the return line of the cp3 to the fuel filter housing would help some? Or am I way off here?
I even thought about installing one in the supply and return line.
I am under the impression that a fuel heater is needed for low temps to keep fuel from freezing up. So if it is 70 degrees or better outside , would the cooler fuel help at normal engine operating temp?
Thanks for the input.
