gtwitch,
Uhmm, nope! The engine in the Freightliner sits much higher than one in a Dodge and the fuel tank is no closer to the lift pump, maybe even further away and possibly lower in relation. As I stated above, the fuel filter is located on the drivers firewall which is a good 2' higher than the lift pump. The Freightliner situation is actually worse than the Dodge.
Guys,
While I agree wholeheartedly that DC could and should have done better engineering it is a moot point. If they built them the way you and I wish they would we couldn't afford them! They are in business to make money, period. The market dictates what a particular vehicle will sell for. If Dodge built them well engineered to last they would have very few sales because folks would buy Ford or GM instead because the would be less expensive. Can't make money by not selling vehicles.
I was simply responding to statements that were made along the lines of "DC is the only stupid manufacturer that did this with the Cummins" when that simply is not the case.
I have owned the Freightliner Thomas bus and three Dodge Cummins, one each of 1st Gen, 2nd Gen 12V, and 2nd Gen 24V and still have two of those trucks. With the exception of the bus which only had 55,000 miles on it when I sold it I have done work to all of them. In fact I am having the Dana 80 in BlackSheep repaired next week because a pinion tooth broke after 680,000 miles. I have replaced the VE pump once and the VP44 twice. Put head gaskets on two trucks. But it's ok because I work these trucks hard, not abusively, just hard. And they have far outperformed what a Ford or GM would have done, with fewer breakdowns to boot and still have a lot of life yet. Are they perfect? Absolutely not! But we aren't living in heaven yet, we are still on the outside of Eden.
I'm not flaming here guys, just trying to bring a little perspective.
Godspeed,
Trent
