Does my 93 W250 have a plug in block heater?
Add-a-Leaf
I Smoked out a Duramax..
My 96 had a wall plug wrapped inside the engine compartment. I cant seem to find one in my 93 Cummins W250. Any ideas where it could be hidden?
Thanks
try looking in front of your air filter canister, or maybe hanging down by your jack, anyway it should be in that general area ... ... ... RD
93 W 250, Banks,B&D,K&N,JRE,Rickson 19. 5's,FourWheel camper. <A HREF="http://rducsh.homestead.com/truck.html" TARGET=_blank>
Truck Spec Site</A>
<A HREF="http://albums.photopoint.com/j/AlbumList?u=279120&Auth=false" TARGET=_blank>
Photo Site</A>
Yup, mine was kinda hidden in a similar place. It was behind the grille, tucked under the windshield washer fluid cannister. If you look sorta behind and slightly back of the oil filter you'll see a knurled alum. knob with the wire attached to it, just follow it to the end and feed the plug out through the grill.
93. 5 D250 4X4,HD Spring Pkg, Rancho 7000's, Rear Swaybar, Dual Shock Front Stabilizer, BD Injectors, 3" Mandrel bent exhaust, 16cm 'Hot End', Modest Pump Tweaks/Timed, K&N Air, Isspro Pyro,Tach,transmission Temp, Auto Meter Oil Filled
Boost Ga. , 3:54's, 4 Speed Auto, Clubcab, Aftermarket Reclining Buckets w/ctr Drop Down seat/console, Black over Silver, 21psi,285-75R-16's,American Racing Clear Coat Mags, Amsoil 15W-40HD Marine, 12,000 lb. Warn Winch, KC Spots.
97,000 Kms.
I still have to figure out why my block heater doesn't want to work. Can't look at it this weekend however, headed up to the Buckeye to see family. Happy Thanksgiving to everyone and their families.
'93 D350 2wd Club Cab 5-speed,143,000 miles,K&N,Amsoil throughout,Borgeson Steering Shaft,Isspro gauges(Tach,EGT,Boost,Engine Oil Temp. ),16cm Turbo Housing, "My Dream Exhaust"(5" Chrome Stack)
after locating it on my '92, I tucked it under the frame rail and zip tied it to the front of the frame between the strut rod mounts. It's out of harm's way and easy to reach. Best of all, there's no ugly plug sticking out of my grille.
With the wire secured, I set the plug head inside the small lip of the frame. It stayed there day in and day out for the whole year. It never fell off or dangled down. I certainly don't baby this thing either. It's been airborne and bounced around regularly.
Look on the Pass. side of the block next to the oil filter. If you see the plug in the block, just follow the wire to see where it may be hiding.
Scott
92 Ram, Bright White, Club Cab, LE package, 4x4, 130K, 3. 54 gears, Auto, Extra transmission Cooler under bed, 285x75x16 Cooper Discovery A/T, 16X10 American Racing rims, Rancho RS9000 all around, Tekonsha Brake Controller, Running boards, Lund Sunvisor, Marker lights, Lund bug deflector, Tonneau cover, Full cap, DynoMax muffler, 5" Chrome tip, 16 cm Turbo, Isspro Boost gauge, 23 lbs Boost, Pump Adjustments, Sprayed in Bed-liner, Rubber mat
'SHAKES, RATTLES & GOES'
