Does the 06' CTD 4x4 have any grease fitings?
Install Air Horns
Spare feul tank
This past weekend I was driving back from a trip I took up to NW Texas. I stopped in Houston for a oil change, lube, ect. at the dealer I got the truck from (Helfman Dodge). I have used them two times before and had great service. Anyway, the service writer got me in and out in less than 30 min. My question is this, the service writer said the tech would lube the chassis as part of the oil change, but when I picked up the truck from the tech when he was done he told me that the 06' had no grease fittings on the chassis or drive line.
Bottom line, whats the deal? Does the 06' have them or not, if so how many and were.
Thanks in advance, -Troy
the only ones i found on mine are on the tierod... so much for the sticker on the radiator support saying to grease the front driveshaft because mine doesn't have any... i would rather have a sticker for the routing of the serpintine belt :-laf
My 06 has the driveshaft fitting. It's just very hard to find for the first time. I'm sure yours has one too (if yours is 4wd). You need a needle to grease it. If you do a search here, you'll find some photos of what it looks like. Did I say it was hard to find?
