Well, the title says it all, but here's a more specific scenario:
Let's say (hypothetically) that I'm at 450HP and I'm running an HTB2 with a 12cm2 housing that's rated at 450 - 500HP. Assuming that water/meth does really add 60-70HP, does this put me in the range for something like the Killer B2, which is rated at 500 - 550HP?
OR, does the reduction in EGTs from water/meth pretty much eliminate the need to step up to bigger turbo?
What about the extra boost gained with water/meth? Any potential problems there with the turbo, besides head gasket failure?
Or is water/meth basically a system that you can install on any setup and not have to worry about turbo problems?
I'm new to this water/meth stuff - but I'm learning more everyday.
Thanks for the help once again!
