Originally posted by Forrest
I've noticed this since I got the truck. Even completely stock, if I drive 'easy' for awhile, no full throttle or heavy throttle, & then really get on it, it smokes like crazy. If I drive it 'heavier' more often, then really get on it, it doesn't smoke as bad.
Anyone else notice this? [/QUOTE
Yep,
Mine does this too. I think that it has to do with cylinder temperature. If you aren't working it, the temperature drops in the cylinders and it doesn't burn the fuel as well when you nail it. After the cylinder temps come up it won't smoke as much.
Steve
Makes sense Steve. I wonder if we're building up 'deposits' in the combustion chamber & on the injectors![]()
Now this is hard to do, but if I go 1/2 a tank & never nail it, it'll smoke big time on the 1st full throttle run. Last time it was putting a Quattro & another Cummins in their place.It was really bad back there.
Originally posted by HoleshotHolset
This practice is often referred to as: "The Italian Tuneup"
The derivation of the phrase is not fully understood. It could be in reference to Italian high-performance cars needing to be driven 'spritedly' to eliminate the previously aforementioned nasty deposits... .
Bill Cosby once had a good sketch about how to clear out his AC Cobra. Goes something like this: He bumps into Carroll Shelby in the grocery store and complains that his Cobra is running a little rough. Shelby replies "you gotta take it out and run it hard to get the Gunk out. Just take it to 120mph in second gear". Cosby goes "where am I gonna find a spot to do that?" Shelby says "Any side street".
Think it'll work with our Rams? I know for sure I'm gonna need some more gear to pull 120 in 2nd...
Steve
Originally posted by Brandon
seriously forrest why is the auto plate better than the 10? is it the midrange power???????? [/B]
Originally posted by JFulmer
2 seconds?????? WOW I thought with the way I had my plate and with the 3k springs it went up real fast but nothing like that, I was forced to slide the plate back a bit to control it. I will get the 4" installed next week and see what that helps. What is the #4 in our motors rated for power wise?
Jim
soooooo db where are you at?????
Maaanteca!
