If you are lucky enough to have a sucessful install and it works were you present in the shop when they installed the flash? The reason I'm asking is I'm wondering if the tech had your truck hooked up to the MDS2 (Mopar Diagnostic System)~~AND~~the Scan Tool (DRBIII) at the same time?? Or did the tech just download the flash into the DRBIII from the MDS2 then hook just the DRBIII to the data link like they did on my truck to do the Flash? I was reading the repair procedure in the paperwork he gave me and if I'm reading it correctly both systems need to be hooked up to the truck at the same time for the software to be installed properly and then go back in with just the DRBIII to enable the 3CYL. feature. You guessed it mine dont work yet :{
So if any of you were there when 18-019-01 was sucessfuly installed do you remember?
