Competition Doesn't Make Sense !!!
Competition Test and tune
Off Roading AGR rock ram steering installed
on the way to muncie me and a few of my buddies were playing on the interstate racing and what not and you can see in my sig below what is on my truck and from about 75mph punch i raced a 01 quad cab 4x4 5spd. that had dd III's and a edge comp and i couldn't do anything but pull him by about a fender. :{ then another buddy with same truck except only has a drag comp and no injectors i couldn't pull him at all. i can't figure it out i know everything is working good i can tell that the pump wire is hooked by seat of the pants. any suggestions. :mad: oh, the two trucks were 2500 series but i don't think the weight difference would matter.
Sense
First off by your sig,your pm3 doesn't have timing and the edge boxes do. They got you from the get go because of that. Get you an ez to stack with that setup. That'll make whole world of difference.
thanks for the quick replies. :D we all have 3. 55 gearing and i had a power puck stacked and i forgot to mention that. i didn't get beat i just couldn't do nothing with them. :--)
I think ?
that the Edge EZ and the DD Module are one in the same critter? Edge manufacturers several names on the boxes, but the guts are all the same. Don't take my word for the Gospel, call Ken Jones at Diesel Dynamics and he will give you the true Skinny in this subject.
Dave
Any chance your head gasket is beginning to let go. Mine was blown between cyl 3-4 and 1-2,and it ran fine. I would have kept on driving it like that. We found it when we O-ringed it for nitrous. My boost had been under 50psi 99% of the time. It did spike to 53psi about 3 times. I know the HO's go thru Head gaskets faster than my ETC does
i just put a new head gasket on about 5,000 miles ago and i have my wastegate set at about 39#s. i don't know it could be going again. :--)
