D'oh!, Need cam timing advice
06 problems - voltage and relay
Shifter replacement
Im doing a cam swap on a 04. 5 and I forgot to mark the gears when pulling the old cam out. Any advice on how to time the new cam. The cylinder head is also off, so it will make it easier finding TDC #1. .
Thanks
There is a "0" on the crank gear and a "OO" on the cam gear.
When the two are engaged you are at TDC. The picture above depicts an engine that is 180* from TDC. Notice the "OO" (near the fuel pump gear) opposite of the "O" on the crank gear.
