After doing lots of searching and reading I have a few questions. My truck has 207,000 and I got it with 160,000. I plan on doing a decent amount of towing this summer (my car to autocross/trackday events/dragstrip) so I figure I should make sure the truck is prepped. I have Hawk Severe Duty Pads, New Raybestos Rotors (premium, but no slots or dimples), new hoses (mine are showing their age) and reman calipers.
My questions: Regarding the hub assembly. Having never done this before how can I check the front hub/bearing for wear? Or should I just replace them and be done with it?
Looking at my brake lines, the metal line appear to be pretty badly rusted, so much so that I an concerned that when I put new rubber lines in I might run into a problem. Have other had similar problem with the metal lines?
And in doing the reading I am a bit concerened about the axle shaft seals getting damaged in this whole process. If this happens, what kind of a job is that to replace them? I had an alignment done at the end of 2007 when I bought new tires and at that time the ball joints were good, and the truck tracks straight both going down the road and under braking.
Lastly any special tools? I think the spindle/hub nut is 1-11/16ths from what I have read?
Thanks
Chris
Thanks
Chris
