Alan Reagan
What a PITA with the hidden bolts on the EGR cooler. Last night, I finally got the two inside nuts off. Let me correct that. The studs came out with the nuts. Both nuts are cross threaded. This is the first time they have been off. Must have been a bad day at Cummins.
I called the dealer. $40. 00 for the studs and nuts. I went to all the part stores and couldn't find stud sets that length. I tried a nut cutter. No joy. I was just going to replace the nuts. Since I have extra time, I've done the throttle body, butterfly valve, CCV filter and everything else I can see that needs some attention. I may have found a solution to the hidden nut problem. I will post again tomorrow after I put it back together. I went to all of the local parts stores. NAPA had the closest replacement studs and they were class 5. Apparently, the OEM studs and nuts are a soft alloy, non magnetic (read plated brass). At least my magnet won't grab them. I'm ready to be done with this. I would think the dealer would carry them in stock instead of ordering them all the time. I may use the class five bolts with anti seize. The OEM bolts are too soft and round off with the first slip.
The kicker is, most of my miles are highway and the cooler and butterfly were not as crushed up as I thought they would be.
