2nd Gen Non-Engine/Transmission Dome Light Bulb Replacement
Engine/Transmission (1998.5 - 2002) CB in Truck
Engine/Transmission (1998.5 - 2002) Oil Changes and amounts
I'm probably the only dummy that would make a big deal out of replacing the dome light on my 2001 quad cab but here goes. When I started tugging on the dome light to get to the bulb it felt like I was going to break something in the process. What I learned was don't just pull down on the dome light. Slide it toward the passenger door as far as it will go and then drop the drivers side down. EZ. Then the bulb retaining assembly lifts away from the fixture in one piece.
Great post!!!!
I was wondering about getting the bugs out of my dome light.
Thanks to you I won't be reaching for the torch to cut it out;)
V/R
Breck
