Yep! Wires! Seems to be very common on that door... opened more than the passengers side I suspect. Just pull back the rubber boot and the crimped/cut wire will be obvious. It's an easier job if you have a second set of hands to hold the boot back while you splice the wire(s) together. I have progressively re-connected all the wires on that particular door, speaker, window, door lock etc. Very easy to do and a lot cheaper than the cost of a replacment wiring harness from the dealer.
