Details here: TDR Privileges
I changed the fuse and power good to fuse, but I still dont have them working. The dome light, glove box light and radio all quit at the same time, any Suggestions?
As several fuses can often cover (protect) the same circuit, whenever I need to check fuses I use a test light with a fine point and check each side of all the possibly pertinent fuses, in place. Likely you'll find one that is hot on one side and dead on the other... A lot easier than unplugging them all, one at a time. .
try fuses 15, 32, and 51. I looked in the fsm under interior lights and these are the three fuses listed. For the audio fuses its 21, 43, and 51. So Id look at # 51 first. This is from a 05 FSM if it helps.
