Donaldson Muffler Installation
Sheared crank pulley bolts
Small transmission leak
Hello,
I have an 06 megacab and have a question about the installation of the 51" Donaldson muffler, which I am considering purchasing.
My stock muffler is not a straight in and out design, it is offset, the outlet is probably 4 inches above the the inlet. The Donaldson is a straight thru design.
How have you delt with this?
Any pictures of an installed donaldson would be great!
Thanks in advance for any help.
I have one on my truck. It was not straight through, but I made it straight through. The megacabs also have an extra muffler just aft the axle. My entire exhaust is a straight through and it is no louder than stock. Here are before/after photos of the muffler before I installed it.
Hello,
I installed the 51" Nelson and it is straight through so I these pics might help. I noticed the CAT dropped the pipe and the muffler brought it back up. Since I was removing both it was real easy. It took one slight angle change where the tail pipe goes into the new muffler to make it line up perfectly.
This is looking down the exhaust from the front. The crossmember you see in the bottom of the picture was where the cat used to be positioned directly above.
You can see the weld where I made the slight angle change.
Not a great camera angle but you can see how the cat has a drop in the pipe built into it and the muffler design brings that back up.
Hey Brista, did you have an EGT gauge before you did your exhaust? I am always curious what the EGT drops are going from a completely stock exhaust to a 4'' striaght through.
Yup... dropped 25-50 degrees.
If this only dropped you egt's buy a few degrees I am not sure it is worth the investment of time and money to switch, especially considering that I am not taking the cat. off and probably will not get as big a drop as you did.
Were there any other benefit, besided the sound? Better mileage?
Thanks,
Bret
I was hoping for a bigger drop, but this is only cruising EGT's. Unfortunately I am just getting into the towing season now so will have a better idea how that is affected soon. Mileage gains are hard to track as we were just going from summer to winter fuel when I switched it. My mileage stayed the same on winter fuel so it did help. We are just getting back into summer fuels now and I expect an immprovement.
