Don’t forget Sun Roof Drains
New 2500 2020 trucks
2013 Ram 3500 "Service 4WD System"
Stab
Washing the 3500 w/sunroof. It started dripping water from passenger side grab handle. Water was coming from the sunroof drain pan @ the front of sunroof while open. The right side drain was plugged. Over flowing the pan & draining into the interior down the A pillar into the grab handle housing. Drain goes from both front corners of pan to area behind fender & door. Easily seen when door is open. Blew out with compressed air.
I do the same thing but I adjust the pressure regulator so I don't blow the drain hose off the drip tray. I also took some bull head snips and cut back the black rubber drain tit by the door hinge so the smallest bit of crud no longer plugs it up.
