I just completed the install of 19. 5 wheels that thru off my mph so I got a True speed calibrator, simple hookup and it has a switch so you can run 2 different size tires and simply throw the switch for either set, well I got to thinking that if a feller were to use setting 1 for actual and then use setting 2 with it calibrated way low than the puter would never know that you were at 115, I aint tried it yet but with my 19. 5 x 285 wheels I dont think I would run outa r's till around 125-130 mph
OH and this way you wouldnt throw any codes at all (vs. shutting the wheel speed off all together)
Cheers, Kevin
Cheers, Kevin
