Thanks Cummins, that sounds a lot easier than it looks. Now, will it be hard to get parts now with all that is going on? That would be a dealer only item. The pin that the door hinges on is fine, its the spring that is the problem. It some how jumped out.
I have my old hinges here, they just need pins & bushings installed. The spring is easy to install, but I would get it from a junkyard before a dealer. Check LMC truck, they might have them.
