Door lock problem
Tie down points in the bed
Mufflers
The driver side rear door lock on my '05 quit working. It will not work with the key fob and will not work with the door lock/unlock button. Only manual. I think my 3 year old daughter may have been messing with it (mischievous little critter). Any ideas or help would be appreciated. Thanks.
Check the wire harness from the door jamb to the door, I have seen these break from the flexing of the wires when you open and close the door... .
i thought the broken wire was from around the 03-04 model not an 05-06...
I have the exact same door problem. interment at the moment.
