2nd Gen Non-Engine/Transmission Door lock switch disappeared
2nd Gen Non-Engine/Transmission rear axle seal change
2nd Gen Non-Engine/Transmission turn 2wd into 4wd. any welding?
Pushed on the power door switch on the drivers to lock the door and the switch fell down into the door cavity.
Should i pull the door panel off?
LOL. Removed two screws holding the black concave handle from inside of door.
Then used fingers to dislodge the switch assembly.
The pwr door lock switch should be attached to the housing. The switch has two bumps and the housing has two slots. The slots are broken from the housing.
Will look for a replacement housing tomorrow.
KRS
