2nd Gen Non-Engine/Transmission Door Panel
1 screw by the mirror, 2 screws in the plastic arm rest handle (not the latch handle). It's easier with the tool to slide in behind the clips, but it can be done without it. I think they're less than $10. at Napa.
You'll want to get some new door clips before you begin. Its likely some of your old ones won't survive the removal process.
You don't need the tool but it is definitely worth it. You will be amazed at how much you use it for popping all the little push in reatiners. Grab some new Clips aswell cause you will break them. Good luck
Thanks all I really appreciate the helpful input does anyone know the name of the tool used to remove clips? Thanks to all in advance
I believe it is called a "door clip remover". You can find it at any national auto parts store. If you have roll up windows(non electrical) you will need that tool also.
I just pull it off by hand then use the tool to get the christmas tree cilps out of the door, you wll have to slide it over inside doot handle and door lock.
I have one like this:
They vary in price from $4 to $10 at your local tool store. I wrapped the shaft in electrical tape so it doesn't scratch the paint.
