2nd Gen Non-Engine/Transmission Door pin bushings
Engine/Transmission (1998.5 - 2002) Thermostat 180 or 190?
Engine/Transmission (1994 - 1998) Charging problem
Has anybody found a good source for door pin bushings or repair kits for a 94 ram? I bought a kit off ebay that said it was for a 94-01 dodge ram, and they arent even close to the right fit. Not sure if 94 was different, but if i cant buy a kit i will just have to spend the money and replace the whole door hinge, which looks like a lot of work, and about 500 dollars!
thanks for any help
Thanks for th replies. I heard back from the guy i bought the bushings off adnd he thinks that i have the older style bushings (93 and older) I measured them and the bushings all measure 1/2 inch OD and 3/8 ID. The 94-01 rams should have two different sizes of bushings. Im thinking maybe there were some 94's that had the older style, and some with the newer style??
Anyways he gave me part numbers for NAPA and ill let you know how it works out. Here is what i got:
84-93 Dodge truck
8030192 Long Pin 4ea
8034663 bush 8ea
kevin
