Door Window Channel Replacement....
Truck questions
2000 ohm resistor din't do the job; ABS and brake lights still on!
Has anyone replaced the Window Channel in the doors of our First Gen's?
Mine seems to stick or drag when cranking the window 'down' but goes 'up' beautifully. Anyone else have a worn out window channel?
Tim "KEENO" Keen :D
Keeno,
I've replaced the channel that the window sits in. (My wife is rough on the window. And right before we pulled into a TDR event at a Dodge Dealer!) Not sure if that is what you are talking about. I pushed the window up, got it on track, and then let the window crank press it in place. Not bad.
