Double Cardan Centering Ball Seal
A/C Clutch Fuse keeps blowing
Cleaning Rear Differential
rbattelle
For those who have had their front driveshaft apart, does the seal shown in this photo get pressed onto the socket?
I suspect the answer is "yes", but I want to be sure before I try to beat the thing on there. Seems like it's going to take a good pounding.
I think it popped off during the joint removal process, which I buggered up. :rolleyes:
Ryan
Answered my own question
The answer is "yes and no". Remember when I said I had buggered up the disassembly? It was worse than I thought, because the socket had actually come dislodged from its normal position and I didn't realize it.
Imagine my surprise when I put the piece in the press to press on the seal and the entire socket moved in another 1/2"! Notice the proper position of the seal is pressed into the housing. The socket is no longer visible - it's beneath the seal.
Thank God I decided to put it in the press!
While I was at it, I thought I would show that I noticed a small hole (around 0. 050" diameter) in the yoke casting just behind the ball and socket assembly. This is where AAM installed the grease fitting on 2005-up revisions of the driveshaft.
A grease needle with the proper angle could be used to grease the center ball through that hole. I think I'll try it out once I get the shaft reassembled.
Ryan
That isn't where you grease it at... ... ..... The grease neadle pocket is in the same spot as where a grease zerk would be but it looks like a silver button almost like a rivet head.
Here is a link to a thread with a picture of what I am talking about.
You're right, Bill, the fitting is on the other end from the photo I showed. Did they make the centering stud hollow on the new design?
I think I'm going to bend up a custom needle to add grease to the hole I showed, which will flow grease into the socket and around the housing. Can't hurt.
Ryan
