Double crewcab 4x4 cummin's conversion in the Making
'87 D250 Gas to Diesel conversion
Dodge First gen Era Crewcab Calendar
Simplysmn
Call me Crazy Yes But the chance came up that I found 1 crew cab in Calif and then the blue 1 was bought by a guy in Texas and he has sent it to me to be converted . So the Fun will soon begin . I am working on getting a shop to be able to work on theses . they will not be fancy build's just functionally solid and driving truck's . Going to paint the frames on both just to clean thing's up some . Going to be starting somewhere around the first of Month so Stay tuned . I am not tryin to impress anyone by doing 2 at a time it is just easier for me if I work on both at same time . Plan is to put both on Jack stand's and tear em both down to Cab and frame and rear end then start going into 4x4 set/up first . Then swap Drive train's into Both of them
Yes I put them side by side next to my Beast just to show what they will look close to when done . Mine is lacking Paint and a couple small item's :)
Your going to do what im doing , not fancy just a clean relible truck , Are you rebuilding the 4x4 ? or is that one done already ?
Oh if needed if you go to Ram central site there is a guy on there tha has new rear hangers with bushings thats greasible that has 5/8 bolts instead of 1/2" he also sends a template to use as a pater so you can drill the frame , they work great .
Yes the 4x4 is Mine Finished that Last Feb been running and driving ever sense . I won't run Jungles stuff I like stock yes his stuff is Nice but I'm on a Budget . Both Crewcab's will be turned into 4x4 with a cummin's under the hood . :)
dang where you find all the trucks at. ive been looking for a crewcab longbed for a while and haven't found one yet. you interested in selling that white one? that's looks like a clean truck.
Send me a PM I have a Longbed crewcab for sale if your interested . or E mail -- email address removed -- just put crewcab in subject line Please .
Val
Hey is there any difference on the fire walls ? I'm having issues putting the engine in my crew cab ,I think it's the cherry picker not goving e the right angle , help !!!!
1981 TO 93 Is all the same except for a couple wire holes Yes It's the angle of the cherry picker that is throwing you off .I will PM you my Number if you need help .
As Long as weather work's with me today .I should be moving the truck out front and take a Trip down the road really quick to see how it run's . If everything is good it goes to Muffler shop tomorrow .
